Hellow , i am new in this forum , best regards to all members.
My problem is the next :
I have in my car a Denon Car cassete receiver . I buy a cd discman player aiwa XP-234 for connect to it . It works okey .
But , i have the problem with the batterys ( it agotates ) . I self made one dc car adaptor 12-5v converter with a tipical 7805 IC with 470 uF capacitors and 0,1f capacitors .
The problem is , when i conect de power supply to the discman , i heard over the music , very digital noise ( tipical of the circuits of control of the motors of the transport of the laser head , etc. ) .
With batterys , any problem
I revised groundings , etc. and etc. . i have a pionner alternator noise supresor , direct lines of the battery , etc.
What is may problem
Thanks in advance
What is may problem
Thanks in advance
I answer myself this problem . It can be util for others.
The problem is that i was have a analog/digital ground loop in the circuit formed with the cassete player and the diskman.
When i use the diskman with bateries , this loop is broken and i don't have the digital noises , but when i put the dc adaptor 12v/5v , this loop is established and i have the noise again.
the solution :
i buy a electronic component dc/dc isolated ( more important this ) coverter 12v /5v , and the problem is solved. no digital noise with 12 car batery diskman powered .
this component is from Newport components part : nml 1205s, but they have a full line of voltages and power.
the solution :
