Direct drive ribbon with modified F5T
I currently have a line array with an array of 7 DIY ribbon tweeters. The resistance of the ribbons is a total of .2 ohms. I am planning to change out the ribbons with thinner aluminum which should give me a total of .5 ohms. I am currently driving the ribbons through a DIY transformer.
I am thinking of building a variation of the F5T V2 in order to drive the ribbons directly. The changes are:
1. Lower voltage +- 16v
2. High current PS - good for up to 20 amps continuous (one supply for each channel)
3. 6 parallel output pairs biased at about 6 amps total
With .5 ohms, I think this will give me about 35 watts class A. This should be enough since they are pretty efficient at 95 db/watt. I should get much more power A/B before I run out of current.
Thoughts?
P=I²R
Where you use Ipk the formula becomes
P=Ipk²R/2
Ipk = 12Apk gives the calculation you show in post4.
i.e. for 36W into ½ohm you need 6Vpk and 12Apk
If you want that all to be in ClassA, then the output bias of the push pull F5T must be set to > 6A (continuous).
The supply rails would probably work @ > +-12Vdc
Pq ~ 12+12 * 6 ~ 144W per channel.
Doable ?
your brief exceeds the minimum requirements.
