Hello!
One of my friend connected the mosfet drivers, and the fets like this: http://sziget.mine.nu/~danko/aramkor/smps/car-smps/12V1000W.ps
Have fun!
Danko
Have fun!
Danko
You cannot open it with the browser because it is a postcript file. Danko, could you translate it to pdf for us, please?
About your question, Disney_sk, you have two options: use a transformer coupled gate drive or two high-voltage driver ICs (IR211X from International Rectifier).
Best regards,
Pierre.
Best regards,
Pierre.
Here's a part of that PostScript file:
http://sziget.mine.nu/~danko/aramkor/smps/car-smps/gate_driving.jpg
Unfortunatelly, my friend, who draw it, he draw it into a huge size, it doesn't fit in 1:1 view on my 19" monitor
btw, typing into g00gle the "ghostview download" gives you plenty of PostScript viewer programs.
Under Debian GNU/Linux you just have to type in "apt-get install gv"
P.S.: I haven't checked the schematic.... But my friend works at here: www.pknc.com
He's the electronics-designer.
Danko, the linuxuser
I think you will get more information from IR2110 datasheet and Application note AN987a.
Best regards,
Jaka Racman
Best regards,
Jaka Racman
Thank you all for your replies. In fact, I did not know that IR2110 contains an optocoupler... But now I can see very clearly how it works. I do not want to use transformer drive in my next project, I want to try direct drive, as the guy from d-amp.com recommends... but currently I am out of money
Hi all,
My suggestion is to use gate drive transformers. I play a little bit with IR's and I blow up a few(about 20). There are many aspects that you have to consider if IR's drivers are to be used.
First of all the IR's drivers don't assure galvanic insulation.The high side channel is build in a so called "isolated silicon tube".One of the most important thing is the PCB layout.Take care of undershooting.
Because of the layout I had to many incidents and finally I "fixed up"a few PWM controllers and an ATMega8.
After two months I could make a good PCB for an inverter that works fine with IR's, but was two expensive months of trial and errors.
So, if you have some "extra money" you could try to build your bridge but be aware of pcb.Use ground plane.Helps a lot.
Sorry for my english.
Regards,
Florin
Regards,
Florin
- Power Supplies
- Direct drive in full-bridge topology
