Direct coupling without servo/global feedback?
This design by Wayne Kirkwood is direct coupled (all DC) and only local feedback within the THAT1646 or DRV134 driver IC. Overall, no global feedback. It sounds and measures excellent. One of the lowest distortion headphone amps I have measured.
Simple Class A Headphone Amp Using THAT1646
I like that concept. I think I have an idea using a THAT1580 in headphone amp.
It wouldn't be ZFB but it would be something interesting to try.
There are much simpler ways for biasing the output devices.
Just move the feedback loop to pin2, and you get the same thing.
The THAT1646 only does this for you inside the chip.
For headphones and normal opamps, just change the 4.7R to 470R.
Patrick
Here is another DC coupled design with all discrete components. It was designed by member TimS. It does have a feedback path, but not a traditional topology. It sounds great.
Simple High Performing Headphone Amp
682713d1527107266-simple-performing-headphone-amp-2sk209-headphone-amp-cascode-png
It was a perfect candidate for a home-etched PCB.
685055d1528173694-simple-performing-headphone-amp-img_1816-jpg
I tweaked some of the resistor setpoints to allow use of all BF862’s. With adjustments, it would work with all 2SK209’s as well vs mix of J111 and 2SK209. A very transparent highly resolving, and dynamic amp. It’s Class A and has a dominant second harmonic output but overall low THD.
685361d1528330028-simple-performing-headphone-amp-tims-simple-hpa-1-0vpp-42ohms-fft-png
Using a DCDC based PSU cleaned up some of that PSU mains noise
688827d1529986528-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-tims-hps-dc-dc-psu-142ma-1-02vpp-47r-fft-2-png
