as the thread title says, i need som crossover design help for my speakers!
the speaker currently consists of L.cao 8" fullrange speakers mounted in an open baffle on top of 2x15" woofers.
i currently use a minidsp 2x4; the L.cao's are driven by some Quad II monoblocks and the woofers by a rotel rb1510 icepower amp.
the only problem is that the l.cao needs a lot of EQ above 4000hz, and even then it lacks some top end sparkle.
i therefore plan to throw some tweeters into the mix, and as a planar lover, the tweeters on top of my wishlist is a pair of ESS AMT units
now the big issue here is that the tweeters need to crossed over with the L.caos, but the Quad II doesnt like loads under 8ohm, so as far as i understand, i need to make a series crossover.
i dont have much experience making passive crossovers, so please forgive my ignorance if i do something stupid
here is my first go at the crossover, as i want to make the AMT play as low as possible to evade the issues around 4khz.
i figure the sensitivity is close enough between the two speakes that i wont need an l-pad on the L.cao.
so, is this the worst plan ever, or something we could work with?
[IMGDEAD]http://img651.imageshack.us/img651/4048/img20120902172422.jpg[/IMGDEAD]
