Can I place silicon diodes in parallel so as to achieve higher continuous forward currents than it would be possible with just one?
Any gotchas?
Any gotchas?
unlikely to work efficiently.
The one with lower Vf will hog a bit of extra current.
It will then heat more and hog a higher proportion of the current.
It will do this positive feedback trick unless you can introduce negative feedback.
oh, like we put a tiny resistance to parallel transistors to prevent thermal runway...
Hmm, it seems hard to find 6A + rectifier diodes, non-schottky. Currently aiming at this:
IXYS SEMICONDUCTOR|DPG10I400PA|DIODE, FAST, TO-247AC | Farnell United Kingdom
Putting diodes in parallel is not a great idea, but adding series resistors to help balance them will help. I would recommend using a single diode
that can handle thge required current.
Connecting a transistor with base to collector will act like a diode, but the reverse voltage rating will be only about 6.8 volts. The 6.8 volts is a generalization, but that is typical of the base emitter junction.
How about putting a high voltage, low amps diode in series with the base pin, will that help the base-emitter junction? Will it also cause the transistor now to act as a diode but with 1.2V drop instead of the nominal 0.6V (at low currents) ? I am not at home to try this on the simulation just now.
You want over 6A, but don;t want schottky. Do you still want fast recovery as your example part has?
Since this seems to be a power supply application, have you considered a bridge? They commonly are available in substantial currents. Is the TO package a requirement, or can they be shaped otherwise?
I want something better than the 1N5401 series, those are 3A. I have nothing in my drawers for say 5A or 6A, except as you said bridges.
I was told to stay away from Schottky because of leakage currents and other stuff 🙂
I do not know why you are having a hard time finding diodes greater than 6A, go to the phone book and look up a company like semikron or westcode, There are 3 westcode 1800A 1600V diodes on top of my fridge.
For smaller stuff the MUR8xx and RUR15XX TO220 package diodes are common getting larger the stud mount DO packages start at 10A and go around 400A Unfortunately they get expensive
Bridges in 25 35 and 50 amp are common and cheap 100A are available but assembling from 2 diode modules is popular in this current range.
Diodes are used in parallel and they share current if matched, that is how rectifiers are built to handle 10's of kA.
6A10
http://www.diodes.com/datasheets/ds28009.pdf
Here is different options from UK Rs components. a local electronics store should be cheaper. I paid ZAR 1.00 for per 6a10 for one of my projects.
Taiwan Semiconductor | Semiconductors | Discretes | Rectifier | Diodes - Rectifiers |SF63
Fairchild Semiconductor | Semiconductors | Discretes | Rectifier | Diodes - Rectifiers |RURD660
diodes in parallel will ease the surge problem. I've done this in my amp to prevent blown-out of single HFA08TB60 at power-on. For high continuous current, single capable diode is better.
- Power Supplies
- Diodes in parallel
