diode rectifier ratings
a PSU for class A/B 80w amp....full wave rectifier question:
If the design calls for a 35a bridge, but I want to use 4 diode rectifiers instead, what amperage should each diode be?
Is it:
four 8amp diodes = 32amps?
......or should each diode be 35a.....naw, they'ld be huge :irked:
=RR=
this is going to sound completely opposite to my usual play safe philosophy but let's just describe what is in my Sugden P128s (about 180W into 8r).
Each 52Vac winding passes through a diode bridge formed from four 1n5404s, feeding 20mF charged to 72Vdc. Iq=300mA.
They have never gone pop and there is no soft start.
So the dual polarity supply +-72Vdc is fed from 8 diodes as two bridges in series, the centre point being PSU 0volts. Yes, 3A diodes seem to be very reliable.
sivan_and said:
28-0-28v, @2.7amps....its too small VA for 80watts class AB
You are correct, I was exagerating the specs a bit.
AndrewT....you rebel, life on the edge is sweet !
I'll most likely use the overkill 35a bridge, but was hoping to use four 6 amp diodes I have........they fit better in the enclosure.
Oh well.
=RR=
It still has me thinking.....
What is in a 35a encapsulated bridge rectifier ? :scratch:
Are there really four 35a diodes in there? :magnify:
......or are the diodes lower value, and the encapsulation/termination-package qualifies it to become rated at a higher amperage, compared to individual (discreet) diodes ?
:snail: :whip:
=RR=
