Diode case with black band in the middle
I have faulty High Powered Battery Fence Energiser PCB.
On the circuit board there is a diode case component with wide black band in the middle marked as Unknown component on the picture, linked with S2800D Gate. I measured unknown component across with multimeter and it is in 'Open' state. Can it be faulty zener diode? If yes, how then to find the right value without circuit diagram ?
Can somebody help me to identify unknown component on the circuit board?
Yes, and the breakover voltaage (in both directions) is usually plenty high that a junction test setting on a multmeter is useless. You'd need a curve tracer or a current limited adjustable voltage source to actually test it. The good news is it's probably OK.
