diode bridge using trannies
hello everybody
i'm working on a SMPS and i need a fast diodes to make a bridge
i wonder if i can use transistors as fast diodes , for example taking emmiter and base and connecting as one diode
the switching freq is not too high - 10khz.
i got many mj15003/4 trannis can i use those as diodes?
Why would you want to do it??
I don't have the datasheets for those particulat transistors
at hand, but most transistors won't perform very well as
rectifying diodes. The max reverse voltage of the BE diode is
usally on the order of 5 - 10 V only and the current handling is
not likey to be very good either. The BC diode would stand
more reverse voltage, but I guess there are still problems with
the max base current, not to mention the base resistance.
