Today is the beginning of the incandescent light bulb ban - 8-1-23 !
https://www.cnn.com/2023/08/01/business/incandescent-light-bulb-ban/index.html
What do we do to design a DIm Bulb Tester Now ?
Appliance bulbs come in wattages to at least 60W, but 75W and 100W seem uncommon now.
1000bulbs dot com seems to have a fairly good selection of incandescents.
I've never needed bulbs. I do amp bring-up on a current limited PSU at say +/-12V @ 200mA to begin with to see if there are any obvious problems. After that I slowly crank up the voltage to the limit of my PSU +/-30V @ 300mA. If it works OK there, then I connect the real PSU without fear.
I deal with most Tube Amps for the stage. Fender, Ampeg, etc.
I just made a Dim Bulb tester for a friend who wants to work on his amps fand I found no larger wattage bulb in a Big Box store.
Today I saw in the News the Ban on Incoudence bulbs and wondered how to design Dim Bub tested with the currently available Watt bulbs.
To reach the wattage needed, 60-100 watts, I'd use a series-parallel circuit to get the load needed but wonder if the elements will glow properly to give feedback as to the conditon of the Amp ??
150W bulbs are still available, and there may be 100W traffic light bulbs or similar available from some suppliers.
I use whatever I can get.
https://www.amazon.com/Frosted-Inca...nt+light+bulbs+100+watt&qid=1690934476&sr=8-6
Act quickly.. 🙂
Act quickly.. 🙂
I understand the relative wattage of the bulb and the current draw of the DUT dictates a specfic wattage of the bulb for the best results/feedback as an indicatator of problems
Not to worry, all you need is one incandescent light bulb. Preferably a low wattage one. Then you can use switches to parallel that with anything from power resistors (expensive) to a length of surprisingly easy to find nichrome wire.
You can buy a coil of wire quite cheaply. To connect to it you will most likely want to use a crimp connection. You can wind it around a piece of ceramic rod and essentially make a tapped resistor. Be sure to put it in a heat resistant container to stay electrically safe.
Otherwise you can get a 250 watt adjustable power resistor and add a few more of the slide taps. Note you probably do not want to tap it at less than 50 ohms for a 120 volt AC line.
The small light bulb will give you a visual indication and the resistor homemade or commercial will do the power limiting.
I have under my bench in a metal box 250 watt power resistors brought out to 5 way binding posts. With a few banana plug jumpers I use this as load resistors. I can easily do 4 to 16 ohm loads for amplifier testing.
In my community 60-100 watt light bulbs at NOT available!
Hence the reason for my question "What do we do to design a Dim Bulb Tester Now ?"
I greatly appreciate the concert suggestions that have been made !.
The Ban says they are NOT to be sold.
just did a search on amazon and ebay
still there.
colored lights are except as well
so lots and lots of 100 watt bulbs
be about 6 bucks
still there.
be about 6 bucks
Is it legal for you to buy these in small quantities from country external suppliers?The Ban says they are NOT to be sold.
I have boxes of these stashed away some decades ago 😉
In retail stores in S.W. Michigan 60-100 watt clear light bulbs, None are available !
Basically, I'm asking for suggestions for alternate designs for a Dim Blub Tester.
Thank You to those who have made concert suggestions.
- Design & Build
- Equipment & Tools
- DIm Bulb Limiter Design under the Incandescent Light Bulb Ban
