I have a friend who would like to digitize his vinyl records and burn to CD. He is set with TT and preamp, but would like advice on sound cards and software.
We're both a bit puzzled at how much difference a higher quality sound card would make for this application.
Thanks 10^6.
Thanks 10^6.
As for everything, the sky is the limit. Some advise, in random order:
- software: Adobe Audition, formerly known as Cool Edit Pro. It has all you will ever need and more, easy to learn and has a lot of tools for cleaning up bad vinyl. And it is affordable, even cheap for what you get. This if he uses a pc, for a mac you will have to ask elsewhere....
- he has a TT and preamp, good. Check that it is set up correctly, that the vinyl is spotless. Keep the TT as far away from the screen of the pc as you can! A monitor can spew interference like nothing else. More than a metre is no luxury.
- soundcard: a minefield. Stay away from anything with a creative badge on it. They can only sample at 48kHz, and if you use anything else it will pass thru a samplerate convertor that I still have to be heard praise. Lot used for this job is the Echo Mia. I like the RME stuff, but it is expensive. If the budget can carry it, go for a card with a digital input and an external AD convertor. If there are no limits, check the Lynx cards, the top.
The card can make a difference, but not as much as a well cleaned good copy of the vinyl. Once you clear the bottom of the pit, they are all more or less up to the task of archiving vinyl. That is the reason the Echo Mia is so much used, if you want better, you will have to pay substantially more and gain less in proportion. I does make sense to record in 24bit, as the software can then do a better job afterwards. 96kHz is debateble. I don't think it is worth the diskspace.
Before you start recording even the first LP, check the system to make sure you have the max out of it. Record 60sec of silence (with the motor of the TT running) and then do a spectral analysis of the middle 30sec. See if you do not have 50Hz and harmonics (those ove the ocean, substitute 60Hz). If you have, then try to get that as low as possible! You may have a ground loop, or some loose ground or just a badly routed cable. It should be possible to get that below -78dB.
Make sure you also have some decent system to monitor your recording, certainly if you are going to clean up the recording.
tg3 said:I have a friend who would like to digitize his vinyl records and burn to CD. He is set with TT and preamp, but would like advice on sound cards and software.
Thanks 10^6.
mebbe not direct answer,but........
look that your sound card have at least 65db s/n
look at
http://www.a-reny.com/restauration/restaurintro.html
Most modern soundcards do not have a problem wih that spec. But if you are going to measure the noise by recording some silence and then do a spectral analysis, you will find that in the bass region, the noise goes up quite a lot. This is nothing else than the noise profile of the riaa preamp. You can follow it very well.
hello
Unless the lp's can't be bought on CD's it is not a good money saving tip as the time spent can be quite a lot.......
I speak from experience and have only converted my direct cut discs and some rare tape recordings
You are looking at around 1 hours work per 3 minutes music if you have to remove clicks etc manually
Michael
Michael
I can only agree with your calculations and your conclusion. It is not usefull to tranfer the ninth of LvB by vK. If you do this as a hobby and want good results, then you need to count about a week for an album from cleaning the record to burning the cd (if you only work in the evening after work and have some obligation in the weekend).
But there are enough lp's worth the trouble.
Hi!
I have to tell, if you have a good equipment you can do much better CDs than the industrial ones. You can do an A/B-test if you have same music on LP & CD. Then grab the LP and write a CD. Your CD will be better than the "offer" version. You can check your work when testing LP and your written CD. Or grab each CDs and make a difference test on an analyzator software.
I made a lot of restaurations, they are good ones. I have SB Live card, it works very well with my Pioneer SA-540 tape2 "port". I use comp. as a tape p/r I can use the amp's input selector and grab from any connected signal sources easily. 😎 A better card may could be better but I'm satisfied with this one.
It depends on the record's quality.Great Dane said:You are looking at around 1 hours work per 3 minutes music if you have to remove clicks etc manually
tere said:Hi!
agree.
I have EMT930 as source,Audigy in PC.
Software: Sound Forge6 for rec and normalising,then Dart Pro XP for denoise and declick.
if LP is good enough,minimal postprocesing is needed.
Yes, SF is good. I use the SF's directx NR plugins. They're good. I use SF4.5h. I don't like 5 or 6. 6 is faster, but has no those codecs I'm recently using.
An advice: when you want to copy all tracks of the vinyl, that's better to record the whole side (or disk) in one file and make all works on one timeline.
When you finished, you can cut and copy tracks and make fade in - outs. You can manually edit the "extra clicks" at the end of the procedure too.
If you normalizing an album track by track, you won't get back the real volume differences, so you'll loose the dynamics of the album.
tere said:Yes, SF is good. I use the SF's directx NR plugins. They're good. I use SF4.5h. I don't like 5 or 6. 6 is faster, but has no those codecs I'm recently using.
An advice: when you want to copy all tracks of the vinyl, that's better to record the whole side (or disk) in one file and make all works on one timeline.When you finished, you can cut and copy tracks and make fade in - outs. You can manually edit the "extra clicks" at the end of the procedure too.
If you normalizing an album track by track, you won't get back the real volume differences, so you'll loose the dynamics of the album.![]()
Exactly as I do;sometimes (hm,mostly) when LP is not too scratchy,I don't use any denoiser and declicker; that way sound is better.
agree
Sometimes I do the following: record a side of the disc; Declick <b>or</b> Noise Reduction; normalize to -0.01, Waves Renaissance bass, Spectralizer, Native L. Then cut tracks and make fade in-outs. As I wrote, what to do is depends on record's quality.
The bass and spectralizer helps to get back those harmonics, that the music loose on the RIAA-procedure. It's good for pop or rock music, but no so for classics or acoustic. 🙂 You have to use good editing sound equipment and your ears.
Gents,
There is a faster way that actually works. Audiograbber has available a plugin called Alogrithmix. This plugin cleans up 99 percent of the clicks and pops before the wave file is made. The few clicks that remain are cleaned up with a program, like Sound Forge. Another feature that Audiograbber has is its ability to automatically split the tracks for you. That feature alone saves hours of work. Initially, finding the correct settings for your particular setup can be a bit trying, but the results are certainly worth the effort. My computer has a dedicated preamp and turntable for the purpose of digital conversions. The external preamp is handy to control balance and the levels on line in to the computer.
The resulting CDs tend to be better than those sold in strores.
- Analogue Source
- Digitizing Vinyl Advice
