digital question
Hi All
I am busy with a high power smps, I go for fase shifted zero switching type for welding.
These idea I did see has a extra line for switch a auxillary igbt to get a low loss effect and zero voltage switching, however, I need that extra signal.
on the photo it is seen as Q5 switch. I can use a comparator so I can adjust also on time for these switch, on pictures I hope it is more clear, I go try it in sim.
Precision is needed, an comparator needs 1 % timing components?
But maybe there is a other way to do, I do not use a dsp what is original used as part of the welder.
UC3875 or 79 has no extra output for the extra switch output so I need make one, I can use the output transitions
to trigger this like I did see on the picture timing chart.? a comparator for example, because puls length is twice the on delay.
thanks in advance.
kees
I think it is not needed anymore because I have found a passive version of zvs with a coil.
these are completely zero switching also with low load.
I go try this on sim with a fase shift UC3875 chip, also nice for power supplys for amps..
regards
kees
It could be helpful if you would post the full link to that circuit.
Yes you are right, pdf are to big, I put links.
www.yildiz.edu.tr/~fbakan/AGK/agk_odev/4.pdf
http://www.google.nl/url?sa=t&rct=j...CYegqvAuiY32qGA&bvm=bv.76802529,d.ZWU&cad=rja
http://www.google.nl/url?sa=t&rct=j...QZzWwDxdUxUh9dQ&bvm=bv.76802529,d.ZWU&cad=rja
Last pdf (see zip file) is also interesting, timing here, possible with some electronics for Q5 and Q6 switches?
There are a lot more there of this very high efficienty power inverters.
search for them.
greetz
kees
  • noval inverter.zip
