Digital Potentiometer IC sound quality?
I am looking for an old style THT digital log-pot that has an amazing sound, but I am not able to find any advice on the subject.
There is among other the MCP4162 but is it just a log-pot or is it in fact a hi-fi log-pot.
What do I have to look for?
You are comparing a mechanical entity ie pot to active electronics.
So it comes down to what’s your criteria as far as, what’s it to be used for? specs, control etc?
Look at a TI pga2311 part, would it suit your application? The log aspect is just the gain or attenuation vs a control setting
The idea is to make a volume control for a simple preamplifier, I imagine to having phono in -> 47k impedance resister -> volume control -> output buffer -> phono out.
The chip looks very interesting, the question is if a nonvolatile chip is of advantage?
Muses 72323. A member here sells pcbs. A stepped attenuator can be a more satisfying choice though.
If your sources are digital a modern DAC can be used with internal digital volume control which has matured in a way. Two birds with 1 stone.
Take a look at this
PGA2310
I bought this board a few years ago and it works flawlessly, and good sounding.
I would take the complete kit with display and remote control unit that remains cheap enough.
My choice was for Single Power type for simplicity of internal wiring, however I am not currently using it.
Unless you want to insert it in a device you will need a case.
Good find. PGA2310 ain't bad either but one rarely sees it with a rotary encoder mimicking a traditional potentiometer. Rotary still is the ergonomically best way to control volume for many. The one that invented + and -button volume control should be sentenced.
The dual supply type with remote control PRO2 seems the better choice and as one will need a PSU anyway why not a +/- 10...15V type?
BTW beautifully built amplifier, not DIY I think?
I had bought this too (always with PGA2310 inside) built so very well
Burson Audio Conductor V2
The remote control had the same code as my TVC Panasonic, so if I was simultaneously looking at a tennis game by listening to music also I could not adjust the volume of music because it also changed the TV channel.
Contacted the Audio Burson they advised me to cover the IR receiver on the preamp. 🙄
Returned, but it sounded so good.
P. S.: You're correct. I chose the dual power board (slightly more expensive), but I didn't remember that right now.
There is among other the MCP4162 but is it just a log-pot or is it in fact a hi-fi log-pot. What do I have to look for?
Unfortunately, you do not seem very clear on what you want.
Logarithmic, or linear just describes the resistance curve of a potentiometer. Log. matches hearing, so that is normal.
Do you want a digital sound control where everything is done with the digital signal?
Or do you really mean a remote control for volume? They can be different things.
Do you want to be using a potentiometer / variable resistor? Or a stepped attenuator which can be a rotary switch or relay-controlled switching.
Audio quality will then depend on the quality of switches and resistors. From a few £-$ to many hundreds.
