digital or analog crossover?
I'm looking for advice regarding active crossovers for my line-array speaker project. (described in the "which loudspeaker design?" thread in "loudspeakers")
My current plan is to use a three way PA active crossover and tri-amp to bass, mid and treble respectively.
I know some people use the digital Behringer DCX2496 for HiFi applications. There are also already thought out tweaks to improve the fidelty.
On the other hand, I know some people successfully using analog active PA crossovers as well. (for instance the Behringer CX3400)
Choosing between these two units, which one would you believe is abetter choice? Pros and cons?
Thanks,
M
Thanks,
M
I bought a second hand CX3400 it works very well and it is cheap. When you have more money then move over to DCX2496. You will not lose much money when you sell the CX3400.
I am planning to do this.
