multimeters I have:
Fluke 83 Multimeter
Fluke 78 Automotive Meter
massively multifunction meter with signal scope
Midtronics EXP-1000
and I have a few off brand DMMs that I'd rather not use
Fluke 83 Multimeter
Midtronics EXP-1000
Use the 83. What DC voltage do you read with the black probe on pad 3 and the red probe on pin 1? Do this for at least one FET on each end of each row of power supply FETs.
That's a bit lower than I'd expect. What do you read with the black probe on pin 7 and the red probe on...
9
11
12
9
11
12
ooh, that thing is tiny and at a weird angle... I'll see if I can get my probes in there to test it out
I can't get my large probes in there where I feel comfortable enough to not be shorting out pins to other pins and other components... I don't want to destroy the amp by doing such a thing.
Any recommendations on what to do? it's a small surface mount ka7500 tucked in behind the transformers and under capacitors on the PWM board
4.91v on pin 9 and 12.53v on 11 and 12 with the black probe on pin 7.
I used some leads snipped from a resistor and alligator clamped them to my probes
according to the schematic, pins 11 and 12 are both connected to the remote input lead which should mean I should see battery voltage right?
The drive signal voltage is likely low because the DC voltage at the B+ and ground terminals is so low.
Did you have the 1k resistors (or anything close)?
I wouldn't normally want to double-check the drive circuit but I want to make sure that you don't blow out another set of FETs.
I have plenty of resistors on hand, I'm sure I can drum up 1k or close...
in fact I'll check the collection now. how many do I need?
also I'll check battery voltage
back in a quick few
back in a quick few
battery voltage is 12.63v (should be closer to 12.8 on this particular battery) and I have about 20 1k resistors in hand
If you want to double-check the drive circuit, solder a 1k resistor to pads 1 and 2 of each of the 4 FET locations that you were previously instructed to check. The drive voltage will increase slightly but shouldn't increase by more than about 1/2v. If you move the resistor to pads 1 and 3, the drive voltage may drop a bit but shouldn't drop more than about 1/2v.
You don't have to use multiple resistors. You can do one at a time.
I see the rise and drop your describing.
without the resistor from pads 1 to 2 I get 8.60v
and from pads 1 to 3 I get 3.82v
with the resistor I get
7.87v from pads 1 and 2
3.63v from pads 1 and 3
edit: unless I'm checking in the wrong places? I used my probes on the same pads as the resistor leads were soldered
When checking the gate drive, the meter will be on pads 1 and 3, regardless of the location of the resistor.
with the resistor in place from pads 1 to 2 I see the voltage go up from 3.80v to 4.71v
with the resistor in place from pads 1 to 3 I see the voltage drop back to 3.63v
voltage without resistor 3.80v
red probe on pad 1 and black probe on pad 3 for each test at each location
I think it's probably OK.
After replacing the FETs, clamp them down tightly and insert a 15-20 amp fuse in the B+ line. That should protect the FETs if there is a problem.
Will do Perry, thanks for the great diagnosis Doc! Right now, I'm off to Thanksgiving dinner, and probably the casino afterwards out of family tradition. I will get it put back together, probably within the next few hours sometime, and see what happens.
for now, Have a Great Thanksgiving, Eat, Drink and be Merry, and above all, Be Safe! and Always keep your eyes on the children! there's creepos out there everywhere.
Happy Thanksgiving Everyone!
- General Interest
- Car Audio
- Digital Designs M2a Repairs in process
