electronic design is a NUMBERS based game, and digital more so than analogue design.
Indeed. And not understanding the numbers and the science leads to very bad design - not that we haven't seen some blatant examples of that, especially in "high end"...
No, I think most objectivists (and I am generalizing, too) claim that it is a *possibility* that your brain is fooling yourself (and I would not use the word "merely" there). That possibility should be taken into account.
On this, we agree. We absolutely should take the possibility of fooling oursleves into account. However, that would be a different thing than the reflexively dismissive mind set I too often among many (not all) of the objectivist persausion. That mind set doesn't presume to include all relevant possibilities, psychological as well as phenomenological, in an effort to explain what we claim to perceive. Rather, it presumes that the perception is faulty unless scientifically proven to be correct. While this may be proper experimentation rigor, the lack of such rigor doesn't automatically disprove some pereptual observation either.
Absolutely. But at the same time, it would not hurt for the subjectivists to acknowledge that the human brain is rather good at fooling itself, and that there really is no way to know if you are hearing what you think you are hearing without some objective references.
I will certainly acknowledge that. However, objective measurement of human perception is problematic on many levels, particularly, for the hobbyist. Meanwhile, and this is key, the lack of such objective measurement of peception doesn't automatically prove the negative, that one is necessarily fooling oneself. I suspect that, perhaps, the lack of ready and easy to conduct objective testing of human perception (and, aural interpretation) has led some to improperly substitute objective testing of device parameters only.
I think modern research has shown that the perceptual issues are totally normal and results of the way the brain adapts to it's environment, and have nothing to do with delusions or dishonesty.
On this, we also agree. The problems begin when some choose to reflexively decide that either dlusion or dishonesty must be behind any given reported perceptual observation unsupported by objective measurement.
Disagree, we were discussing digital and how to do that, sorry but you hear all folks is wrong.
Perceptions can be fooled, all the time....
Please see my response above to Julf.
But digital, well I'm sorry but if you do digital design and want to do it right you have to do it by the numbers, as with any electronics design, you have to use numbers physics and maths, to think otherwise is total ignorance of the design cycle.
Your thinking is based on a critical assumption. Which is that we necessarily have complete and total understanding about which 'numbers' (the quantifiable and measurable parameters) need to be optimized for the application context of human aural perception, and how then to optimize them. You must keep in mind that we want to reproduce signals for the end objective of human listening, not simply for the satisfaction of a spectrum analyzer readout. So, for some numbers, yes, we certainly know what to optimize. However, perceptual observations still indicate that there is not universal understanding of all the relevant numbers, of all possible device parameters and exactly what it means to optimize them for human perception.
Please understand, I do not believe in audio magic. Like many others here, I have an electrical engineering background - as I feel certain does, Abraxalito. I believe that if the signal consistently sounds different, then the signal IS, somehow, different. I don't feel there is any conflict between the physical science of audio reproduction and the human perception of it. I feel the apparent conflict is due to our less than complete understanding of the relationship between the two.
Now you'll all start waving you hands and shout at me, but it isn't gonna change the fact that electronic design is a NUMBERS based game, and digital more so than analogue design.
And before you shout and scream I am not dismissing listening tests from the design cycle, they are also an important part, but you still need to do the maths.
Funny, my response got exactly the reply I thought it would. If you read the thread you would realise we were discussing digital design and various points regarding such design to get the best results. As it did not fit the audiophile view of the world we were trolling, being dismissive etc, I do not agree, and have been party to many threads where we have discussed things from both sides of the equation to sometimes reach the same conclusion.
Of course all you subjective people often forget, and this may come as a surprise, that objectionist on this site probably listen to music....
Anyway bye bye for now.🙂
Whether we are talking about digital design or analog makes no difference. The numbers certainly do determine our control over systems designed for either domain. No, I think the issue is, as I indicated above, whether our understanding of the relationship between the engineering numbers and human aural perception is yet full and complete. I think many subjectivists are merely saying that their perceptual observations consistently indicate otherwise. I will go further and suggest that the reason some of us having engineering educations have subjectivist sympathies is because our own perceptual observations also indicate otherwise. I hope it's obvious that the human perceptual half of an audio reproduction chain must be fully accounted for, since any audio system is ultimately intended for human perception. 🙂
And I feel that if the signal consistently sounds different, it should be trivial to prove that objectively (for example by controlled, blind ABX tests). The inability to reproduce a phenomenon under controlled conditions is a hallmark of pseudoscience.
If I were ever to do such a test with a large number of subjects, I'd throw in another variable: half of the subjects would be told they would get zero reward, compensation for going through the exercise; the other half would be told that it was a competition, the person getting the most right would get, say, $10,000 prize, and there would 2nd, 3rd, etc, prizes.
Humans being perfect test subjects, 😉, I'm sure this would make no difference between the two groups ...
The notion that measurement should be trivial assumes that you know not only every parameter that's relevant, but also the complete context under which those parameters matter, including dynamically versus time, and all with respect to the interrelated functioning of both the physical audio device and human audio perception. If you are willing to declare possession of such complete systemic knowledge, I suppose, that's your prerogative. However, then it would be my turn to be skeptical.
Meanwhile, I feel we've probably gone as far with this discussion as is useful for the time being. You can have the last word, should you wish.
Yeh here is that last word.
BUMP !
And since you claim to be an engineer perhaps you could explain the subjectivists acceptance of dsp's and digital filters which are only ever an approximation to their analog counterparts. How do you ever live with this conundrum or like most irrational subjectivists do you just pretend it is not an issue ?
BUMP !
How come the same dude thinks it's ok to do an active crossover using numbers and dsp's or does he just pick and choose based on some arbitrary decision which is not based on any rational explanation ?
I'll use my opportunity for a last word just to point out that your argumentation seems rather unrelated to what we are actually saying.
If you go back and read what I actually wrote, I did not say that *measurement* should be trivial. I said "if the signal consistently sounds different, it should be trivial to prove that objectively". Let me spell that out - if you claim that you can consistently hear a difference, then it should not be hard for you to prove that under controlled double-blind listening conditions. As I stated, the inability or unwillingness to reproduce a phenomenon under controlled conditions is a hallmark of pseudoscience.
- Digital Line Level
- Digital, but not by the numbers
