Digital Audio Editing Question
Digital Audio Workstation editing software usually has a 'Normalise' function to enable the final two channel mix to be amplified to digital full scale or a nominated lesser level.
I believe that it may be better to not go to digital full scale, but instead go to one or more LSBs less than full scale.
Question is what minus dB level value WRT full scale corresponds to a few LSBs below full scale.
Any further thoughts or experiences in this matter ?.
Eric.
Apart from that: Every scaling operation will increase noise.
I don't see much advantage in doing this anyway (apart from equaling out the loudness of several pieces on one CD for instance).
If your peaks are really hitting full scale for several samples per half cycle, no scaling will help you to restore the clipped peaks.
Charles
