Differential stage
Working on a Fender guitar amp, the output stages are essentially the same RF amps. I show two red circles on the schematic(collector of Q8, and Q11), I assume the signal at those two points would be the 1Khz input signal pulsing the rail voltage. I see no sign of the 1Khz signal. The transistors seem to read ok. Is there an easy way to use DC rather than AC signal to trouble shoot this circuit?
thanks,
cory
