can someone tell me the different q-values for the different types of xover networks? i believe i've searched the whole net by now, with nothing as a result... i get some values here and there but they are never the same...even if they should be...=( strange!
i need the values for 1st to 4th order 2-way and 3-way Butterworth and L-R...
this will be fun =)
it seems to be some controversy about these values...am i right?
please help me now folks...just a good link would do it!
this will be fun =)
Well,
A small amount of help....
Butterworth is by definition 0.707
Bessel is 0.5
I'm not sure about Linkwitz-Riley, I think the
Q can vary with the design. The details can be
obtained from Linkwitz's web site, www.linkwitzlab.com
regards, Keith
Bessel is 0.5
regards, Keith
Thanks for answering...=)
well...I'm contructing a 3-way ported speaker, a subwoofer with double 12" woofers (ported), a 2-way closed speaker and a 2-way ported speaker...=)
yes...you guessed it! i'm making a complete surround system!
...and that my little problem...I need lots of values...and that's also wy i'm a bit confused about everything, there's simply to much to read to understand it all...
I have another little question, hopefully more easy to answer =)
In a 3-way network, is there any difference between the HP and LP filters for the tweeter and the woofer and the HP, LP filters that makes the BP filter for the midrange (i mean if the calculations differ)?
About the Q-values...I'm most confused about wether the values differ for a 3-way and 2-way...eer...maybe that's what I asked above...
thanks! any help...helps!
Hello again,
Did you try feeding Linkwitz-Riley into a search engine?
Here's what it cam up with. The web site is a start at least...
http://xsspl.tripod.com/Audio/CrosFrm5.htm
regards, Keith
regards, Keith
