Different "Q", same crossover point, different sound?
Let’s talk about the space between drivers at crossover point. If there is lower Q used, it should be wider bandwidth from cut-off frequency of each driver. And narrower bandwidth for the higher Q. Am I right? So, if they are both measured flat combined response, which one sound better?
If you remove group delay...what benefit does a low order crossover have if the speaker is perfectly able to support high order crossovers (48db)....a low order. I read the thread and feel no closer to the answer
Imagine trying to demonstrate what it feels like standing 1' below sea level, but not taking into account that your feet are now wet. Separate problems need to be isolated.
So low order has less group delay, and high order has better polars and time alignment potential? So high order wins because people neglect group delay all the time? Or because linear phase has no group delay?-
I found this
Advantages for low order:
Easier and cheaper to build
Less distortion because of the simpler design
More frequency overlap gives more contact in the sound picture between the midrange and the tweeter
Advantages for high order:
Less frequency overlap gives less interference from the two sources
The excursion of the tweeter is reduced
Less requirements for the midrange/tweeter above/below the crossing frequency
that thread was from 2003 so...take from it what you will. I've been trying to figure out the sonic benefits of low order crossovers, outside of group delay, for my project. The only issue with group delay I have is at the crossover from my 15" mid to the horn. Some people claim they can't hear group delay issues up top, and even more have pushed the idea for bass.
Effect on Music
This confirmed what I had thought: Although I couldn’t directly hear the 3mS time dispersion strongly (except with xylophones and some drums), I easily heard the ear’s nonlinear reaction to phase shifts. The entire musical sound became “covered,” “veiled,” muted, dulled, and de-focused. With this higher fo of 1060Hz, I needed three all-pass stages to notice the effect. That’s a delay dispersion of 1mS, about the same as my threshold with the lower fo of 232Hz (where one stage has a To of 1.37mS).
All of this establishes (for me) that the phase nonlinearity (time dispersion) of most midrange/tweeter COs is inaudible, while I can hear the bass transient blurring of woofer COs from 100-300Hz if second- or higher-order.
Frequency Delay Dispersion | audioXpress
I don't know if this source is trust worthy but if hes legit then minimum phase for me it is....
I don't understand how either of those is necessarily so?
lol you tell me!? Well if they don't cross over in bandwidth...they have less potential for conflict within the time domain right? Isn't banding on the vertical axis due to phase cancellations at crossover? If we increase the crossover bandwidth, won't that intensify? The difference in group delay between two different drivers covering the same band doesn't cause phase issues? Comb filtering?
The transfer function of second order in Laplace transform is s²/(s²+w/Q×s+w²) for the high pass and w²/(s²+w/Q×s+w² for the low pass. if you add the low and the high pass , the band pass function (w/Q×s)/(s²+w/Q×s+w²) will be missing. The higher is the Q the less is the missing band pass sound. I never read on this website about this issue , but J. Hiraga's magazine concludes after trials the 3rd order butterworth to be the best.
What Q are we even talking about? The Q of the filter, or the Q of the resulting response?
I assume that we are talking about the acoustic Q. What would be the point talking about the filter Q in isolation? Filter Q needs to be such to get an acoustic Q that we set as goal. The final acoustic Q that is matters in loudspeakers.
I wrote this in my last post. I don't know why it's missing
"We see lots of us using Xsim Like a video game, Creating a flat sloped response, with good phase tracking and a smooth off axis response, 1st,2nd,3rd,4th order variants plus combos. The various blends are subjectively different."
If there was EQ used to flatten the frequency response around the crossover point what difference would it make?
If the flattening happens to the individual driver responses before the crossover filter applied, then it helps to reach the desired final acoustic slope (and Q ofc) of the drivers when the crossover filters are applied. For example if we apply a Q=0.5 filter to a flattened driver response, then we get a Q=0.5 acoustical slope and it doesn't matter what EQ we used to reach that.
I hope I understood your question well.
I think you understood my question. What you suggest is equivalent to how a Linkwitz Transform works. If we assume the whole system to be minimum phase, then if the resulting FR is flat on axis, it shouldn't matter how we get there? There may well still be subjective differences dependent upon the characteristics of the drivers relating to off axis, power response etc with different Qs
I think that one reason a lower Q crossover is desired is with typical cone-dome combinations. The dome tweeter comes with it's very wide dispersion whereas the larger cone mid(woofer) is starting to beam with much narrower dispersion. The lower Q crossover creates a lower total output (power response) above the crossover where the tweeter have very wide dispersion. So creates a more balanced power response in a reflective environment ( aka listening room).
With a controlled directivity tweeter, there is less need or even undesired that lower Q crossover. All this IMO, maybe IME.
I've come to realize it is a mistake to consider an entire system minimum phase.
A system is really a set of minimum phase regions stitched together to become non-minimum phase.
Typical xovers are not minimum phase. (IIR xovers )
Nor are any summations of drivers that don't operate as an acoustic point source together. (such as coaxial, triaxial, synergy etc.)
Individual drivers are minimum phase, but once combined, nope...
Ime, it's why adding EQs to a speaker in xover regions seldom works (other than to a narrow specific listening spot)
It's also why different "Q"s at same xover freq will sound different, due to different polars.
