Well, yes, your diagram B is not drawn correctly (wrong polarity of input Qs makes for their B-E junctions being in series across the power supply).
I don't think either on them will work very well. The circuit is too dependent on the Vbe drops of the various transistors. It could be that with a zero input the transistor currents will be too large and the devices overheat and burn up.
If so,why certain manufacturer still using them,such as Accuphase???
I can't see why both shouldn't work, however it must be in a very low Current mode for both circuits.
Do you have a scan of actual the Accuphace circuit?
current-mode feedback stage
It will work, but you really need all 4 transistors inside the same package or it can go into thermal runaway. Or, more correctly, force the VAS that follows it to go into runaway. Transistor arrays are a solution, but what really works is the old LH0002 current buffer. The one in the "N" package is required, because the collectors of the second pair are brought out individually rather than tied to the first stage emitters. It really wasn't meant to be used for that, but it can. Elantec used to make a whole family of current-mode op amps with both input and output stages based on that topology.
- Differences between this two kind of input stages???
