Difference btw SE and PSE.
Re: I HATE TO WAIT.
fdegrove said:
There is no definition of "micro details" IMO.
What is often described as such are small level signals present on some better recordings.
Hall or studio acoustics for instance could fall in that category.
Details that tell you about the recording venue being different from one recording to another.
Ok, I'll buy that, but then doesn't that directly correlate to noise floor?
Odd order distortion is very unpleasant on the human ear.[/QUOTE]
I'm aware of all that. I was merely saying I liked the term he used.
Frank said:
the linearity of triodes stemms from them having internal feedback built right in
Yes, I've heard this one before, but I don't beleive it actual has any actual meaning outside of paperspace - another neologism-.
It depends on the complex (tetrode/pentode) being the primitive, which it clearly is not.
My OTL tubeamps have an output Z of 0.14 Ohm after feedback is applied.
Have you looked at the distortion spectra?
Do you think you have any high order harmonics?
Italian tonight?
Cheers,🙂
Bash Frank season!
Tube amps tend to produce more even order harmonic distortion
This is a gross generalisation.
All SE amps do, particularly valve ones.
And that is just considering one stage at a time. With adjacent stages clipping, what's your Fourier analysis?
Valve PP amps, when properly balanced, have only odd order distortion.
Cost: 0.2Eurocents.............
Cheers
HARMONICALLY CORRECT.
Yes.
Predominantly even order distortion of 0.01 % at 1W 1KHz.
Virtually no crossover distortion when switching for class A to B thanks to the absence of OPT.
The extra grids in the penthode/tetrode prevent internal feedback.
Tie these to the anode and you get a nice pretty triode often as linear as you could whish for.
How did this happen?
Italian tonight?
Not me,after midnight it'll be another Cahors perhaps.
Cheers,😎
SHOT IN THE BACK.
It is.
Were we not discussing SE and PSE?
PP:efficency comes at a price and the average penthode tends to produce more odd harmonic distortion as well.
There is a lot that one can say about distortion and how it is perceived but I'ld like to keep a bit for those +1000 posts.
Ciao,😉
Open season
The extra grids in the penthode/tetrode prevent internal feedback. Tie these to the anode and you get a nice pretty triode often as linear as you could whish for.
It hapened because you reverted it back to a primitive 😉
Anyway, nice 1w distortion figures.
But I beleive that the spectrum is important; of course 'odds are out, but what about the higher order 'evens, are you of the opinion (he said resepectfully), that they matter?
THEY SURE KNOW HOW TO KEEP'EM BUSY
Spectrum analysis shows:
First and second harmonic distortion to be most present on a %
basis.
Of the two the odd one is more unpleasant to the human ear.
The cat won't like it either.
Third and fourth order are exactly as the naming suggests:
an order of magnitude smaller and they can not exist on their own,being ovetones of the first and second ones.
Good enough?
Ciao,😉
SERIES CONNECTION.
Hi Thorsten,
You may wish to NOT connect the transformers in parallel, but to use a secondary with 1/4 the nominal impedance and series these.
Connecting two identical secondary windings on two separate xformers in series would give twice the impedance.
So to obtain an 8 Ohm impedance you simply connect both 4 Ohm taps together.
In case the windings would share the same magnetic core your statement would be correct IMHO.
Ciao,😉
Konnichiwa,
brsanko said:
ok but has anyone tried building two amps Identical exept one with one out put tube and one with two in SEP configuration and compared the sound?
Not really. But was done that Kondo San (Audio note Japan) build the Amp's (Branasu/Kegon) and a friend of mine and myself compared. On some recording there was little difference in sound on others the single valve was way ahead in retrieving low level detail, soundstaging etc...
Sayonara
Re: PSE
dhaen said:
Now the leap:
Disconnect the each end of the second primary winding and reconnect it reversed.
Of course there will be no sound because each primary will cancel the other.
So, invert the phase of the signal fed to one valve.
Apart from the DC cancellation, the circuit should act the same...... or will it?
We now have a Push Pull circuit running in class A1.
Does this mean that class A1 PP circuits suffer from the blurring, which is claimed as the downfall of PSE?
Or is blurring a myth?
Very well explained and an interesting point.
Personally, I'd speculate that the circuits will behave the same most, but not all, of the time.
Put say 5 watts at 1kHz through them and there will probably be no difference detectable by normal measurement or listening.
However, consider this point (for both PP and PSE).
Say the two valves are behaving 99.9% the same on a variable basis.
If the amp is passing 5 watts, then the difference will be at a level of 0.1% of signal; .05 watt.
This much distortion on the 5 watt fundamental is itself of no account. However, if the limit of resolution is set at .05 watt, this looks enough to limit the low level resolution of the amp.
Low level resolution gives good detail, good tonality (as harmonics are well resolved), and more of the 'you are there' illusion due to low level ambient information. Are these not the areas where SET can excel over PP?
All of which suggests that the slight differences between valves (PP or PSE) might set a low level of resolution that is higher than that of pure SE.
I rest my case. Well, sort of, while waiting to be shot down in flames. 🙂
Hi Mike,
This is a very old thread, and you are the first poster to get my point: That if there are limiting factors to PSE, then they should apply also to PP.
How about splitting some hairs:
What is SE?
Is a dual plate 2A3 really SE or PSE?
What about grid geometry errors in the same valve?
Could it be that grid geometry errors are the reason people claim that one valve sound better than another, when their DC characteristics are the same?
What I'm saying is: Why can such a dog's dinner topology, ie SE, sound so good? I don't mean the 2A3 or 300B run near limits with lots of 2H colouration. I mean a big valve run at 1/50th or 1/100th of it's power. These do sound much cleaner and better than PP.
Technically the dual anode 2A3 is PSE and sounds like it too.
That's certainly one of the possibilities, IMO.
It's also often so that a single PP sounds better than PPP all else being (more or less) equal.
Cheers,😉
Kuei Yang Wang said:
Konnichiwa,
Sayonara
Not to split hairs here TL, but I remember you writing that soundstaging should not concern us because it is false.
Grid geometry errors will result evident in the Ip-Vpk plate curves, expecially in the strong negative biased region (low current).
The same happens if one parallel more different tubes: the
lower curves are more distorted, a little like a variable mu
tube.
Federico
