Difference bewteen ultralinear & triode mode?
Here is an example at 1KHz of a push-pull 6CA7 in UL mode. The 2nd and 3rd are about equal, although pretty low.
Actually that is labeled wrong.
The top plot is without feedback, the bottom plot is with -5dB GNFB applied.
That's pretty interesting!
In the top plot, I see the 2HD w/o GNFB at a little over -70dB.
With -5dB of GNFB the 2HD is lowered by about what, 3dB?
But the 3HD is barely touched.
I also notice that higher order harmonics go up a bit (way higher, like 7, 8).
In that particular amp, it looks like adding -5dB of GNFB is 'à ton goût'.
Interesting...
Well, I will tell my experiences, even if it doesn't really add too much weight to the discussion. I don't like UL. Pentodes have their good things and their bad things, triodes have their good things and bad things. UL? Not great virtues or defects just....a compromise. A middle point. I'm just not that type of guy.
The amp I listen most is a PP triode amp with no global feedback loop; mind you, a little feedback from the output to the input doesn't 'destroy' the sound, it sounds great too with it but mine, for the moment, stays straight. No corrections. Bass is great (unlike my SE amps), it has a natural sound.... low power but it all depends on the speakers.
And now about pentode amps with global feedback. The ones I've built myself didn't sound that great but I have listened to commercial ones and liked the sound so I don't blame pentodes or feedback, I blame myself because, as it was said before, global feedback is tricky and I just can't get it right. No problem though becasuse triodes are easy and sound great.
...In the top plot, I see the 2HD w/o GNFB at a little over -70dB.
Interesting...
I looked at the "white results"
Without feedback: 2nd -63 dB, 3rd -65 dB, 4th -85 dB 5th -80 dB
With 5 dB feedback: 2nd -73 dB, 3rd -68 dB, 4th -86 dB, 5th -79 dB
NFB improved: 2nd 10 dB and 3rd 3 dB.
There is practically no improvement at 4th and 5th and I assume that these harmonics are already at the input signal.
The obsessive audiophool argument against gNFB is that it lowers lower order harmonics, but raises higher level harmonics, which are 'psychoacoustically audible' even at low levels, because they are 'so unnatural sounding.' Not that I buy that completely, but it would be interesting if the 9th and 10th harmonics came up in level as a result of adding only -5dB of gNFB.
The obsessive audiophool argument against gNFB is that it lowers lower order harmonics, but raises higher level harmonics, which are 'psychoacoustically audible' even at low levels, because they are 'so unnatural sounding.....
With tubes this is a myth.
Below are test results I got a few years ago with a 15 W UL amplifier.
The plot shows the level of the harmonics vs. GNFB
Quite small amounts of feedback, whether local or global, will create higher order terms. In most cases these will still be lower than the pre-existing higher order terms. People who are worried about higher order terms resulting from feedback should never use small amounts of feedback; use either none or enough to suppress distortion.
Clipping is a separate issue.
How is this so when the measurements show that all levels of harmonic distortion are decreased as negative feedback starts being added? I don't see the mechanism by which negative feedback can add distortion in the audio band, except in the case of clipping.
There is a short discussion of this in the 4th Edition of M. Jones "Valve Amplifiers." I don't have that here, but I'll look it up this evening, if nobody else has access to it at the moment. The gist of it (as best I can remember) is that when you put gNFB around an amplifier with distortion, the lower order distortions create a tiny amount of higher order harmonics. His general argument is that adding gNFB to an amp with high distortion won't result in a wonderful low-distortion amplifier, but that creating an amp with low distortion open loop and then adding NFB is the way to go.
As usual, I suspect that the audio folklore is created from worst-case scenarios, then erroneously assumed to apply in *all* cases.
That said, a 7 watt per channel amplifier is likely to spend a lot of its time close to clipping. If the odd, higher order harmonics jump up when the amp clips, then I think that would be significant.
Also, 6AG7 is a pentode. Do things work the same with a PP triode output stage?
artosalo said:
How this result can be explained if it were impossible ?
I don't understand your question. The graph you show does not contradict what I said. It appears to show significant amounts of high-order already present, either from the valve or from the input signal. Therefore the higher-order stuff produced by the feedback is buried under what is already there. The fact that you can't see it doesn't mean it isn't there! In some cases the FB-induced terms will add to existing terms, sometimes (less frequently) they will be opposite phase and cancel.
Also bear in mind that FFT can sometimes show spurious harmonic terms; it depends on things like the windowing function and floating-point rounding errors.
Feedback does two things:
1. create extra terms.
2. reduces everything in the output which is not in the input, including the extra terms it created itself.
You only see 1 when the input signal and the device are very clean (say, 2nd order only) but it is still happening whether you can see it or not.
The mechanism is quite simple: multiplication. An amplifier produces distortion by multiplying the signal by itself, perhaps an infinite number of times. Adding feedback means the whole thing gets squared. Take a 3rd order polynomial (i.e. terms uo to x^3). Square it. You get a 6th order polynomial (up to x^6). Then a bit of trigonometry shows how multiplying sine waves together produces sum and difference products or harmonics.
In order to understand how feedback affect distortion, you first have to understand how distortion arises.
....It appears to show significant amounts of high-order already present, either from the valve or from the input signal. Therefore the higher-order stuff produced by the feedback is buried under what is already there. The fact that you can't see it doesn't mean it isn't there!.....
The harmonic content of my test amplifier at the used power level was actually very small, not significant, since the circuit were fully fine tuned.
If the harmonics were already in the input signal, no improvement due to NFB at later stages would take place.
Negative feedback is typically used to lower the distortion that is generated inside the amplifier, mostly at the output stage.
As my results show, all harmonics are attenuated when NFB is added in practical tube amplifier.
Therefore I hope that such understanding, that small amount of GNFB will increase higher order harmonics in practical tube amplifiers, should be avoided.
The input signal I used with these tests had 3rd and upper harmonics at -95 dBc or lower.
That does not conflict with what I said. NFB will create higher-order terms. NFB will reduce distortion. The net result, with almost all active devices, is a reduction in distortion.
I said:
This is true. Your graphs show that people need not be worried about higher order terms resulting from feedback. This is also true! My point was that people who worry about feedback should not use a small amount of it, as that will do more of what they want to avoid. They should either use none or lots. Their 'intuition' leads them astray.
People who understand feedback, and so don't worry about it, will use whatever level of feedback is appropriate to the situation.
