diamond tip replacement
When the precious tip is worn of your cartridge, what do you do ?
Replace the cartridge by a new one (expensive)
or
Replace the tip.
When the last option is chosen, by whom ?
Didn't hear much of Van Den Hul lately.
Are there others who do replacements ?
thanks,
Dick.
There are two elements that need attention, the stylus itself and the suspension/damping. Back in the MM days, you'd automatically replace them both at the same time. Not so with MCs- make sure that whoever you choose does more of a rebuild than a retip.
