Diamond D3 1000.1 issue
I got this with shorted outputs, shorted power supply transistors.
I replaced the outputs and power supply transistors, including the HIP4080.
The amp voltage is being dragged down, heavy load on PS. Like there is a short. hard to explain.
I removed the HIP4080 and tried again, same thing. I checked the power supply drivers and they are ok.
Also appears to be a hack in the TL494 circuit, 2 1kohm resistors and a cut trace to a 10 ohm resistor.
any ideas? Also what value are the resistors supposed to be at R213/R214 etc... I have 10K
Yea, I had noticed that with the rail capacitors. But I checked all those caps and they appear to be ok.
Turns out the TL494 was defective, Once I changed that out it was fine. Funny thing is, The TL494 was bad, but the driver transistors were good. Figure that out.
Anyway, TL494 was fixed and it was fine.
