Diamond Audio D7401 needs some help
I wish there was a quote function;
Bad connections - Yeah definitely possible but they ohm out fine. There is a lifted trace here, but resistance is fine.
R110 looks fine, but I can see smoke damage on the board below it. Its not burnt, but I see some soot.
I did check all four of the diodes and they test good.
Resistance from transformer end of R64 to transformer end of R110, resistance?
0.1ohms (could be my leads for the .1)
Resistance, same components but diode ends?
I need to grab my other meter, this one is dead again. Are you looking to test the sides of the diodes opposite of the resistor?
To quote, while making the new post, go to the text you want to quote, highlight it and select quote. It will drop into the new post.
Awesome thanks!
You earlier stated that the voltage across c27 was 126v and above the 100v of C27. C27 should be a 160v cap according to the diagram.
You're right about the schematic, but the amp has 100V caps in it. I know the previous owner replaced some of the caps, these must have been a couple of them. I just looked again. C27, C11, C61, and C76 are 100V caps in this amp. Obviously that will need to be fixed. I got my other meter let me see how things look.
From transformer side of R64
D6; Banded - OL, unbanded 67.7ohms
D7; Banded - 67.7 ohms, unbanded 11Mohms and climbing
From transformer side of R110
D26 ; Banded - 67.8ohms, unbanded 12Mohms and climbing
D27; Banded - OL, Unbanded 67.8 ohms
Recheck the voltage on U1 pin 1-2. I don't see a reason that the voltage isn't the same (opposite polarity) that you have on U9.
All 4 of those diodes read ~0.6v when forward biased, correct?
Diodes - More like .48 on those but they are all the same.
Voltage from board (cut pin) of 1 and 2 is about 62v. U9 is about 14.5v
For a sanity check looking at the drawings of U9 and U1 I should be using pins 1-2 for both to check right?
Yeah same deal with the voltage. I am going to remove this from the heatsink and flip it over (who knows what I'll find under there). It'll be a day or so before I can get to it, but I understand what we were working at so I can do a little more investigation and report back.
Off to bed, thanks so much Perry.
