This amp is my friends. I hooked it up. It powers on like normal but you can only hear bass coming out of the sub with the volume at 40 or higher. It is distorted at that volume too. I know this isn't a good thing but I need a second opinion. I was thinking maybe the sound might of blew out part of the way but wasn't sure. If anybody has a explanation please tell me. Thanks
Are you sure that the signal source is in good working order and that the speaker is not blown?
Yeah everything has a good connection. The sub isn't blown. Both coils still read the right impedance and it doesn't have any coil rub or anything.
If you're absolutely sure it's the amp, the fuses in the amp are OK and you want to try to repair it, the next step would be to check voltage at various points.
I just checked the fuses and they are good
- General Interest
- Car Audio
- Diamond Audio D3 600.1
