DHT heater supply
I've been fantasizing about an all DHT amp, with a pair of 26's and 45's. I intend to make it work for headphones, which is my main thing. I don't know if many people have done this, but I guess it's only about getting all the DC supplies super clean and then no problem.
Currently I am listening to my AKG K601 headphones thru my DC Darling, driven with 6SN7 (much less volume than with previous 6SL7, but still way plenty, volume at 21% at source and 50% at Darling). Output is taken at 4 ohm tap. Works great!
But my question is regarding the DHT heater supplies - I would have four heaters to attend to. My first thought is:
In the PSU chassis:
6.3 VAC transformer -> SS rectification (bridge probably) -> 33 ohm 25W rheostat (to get the voltage spot on) -> 9400µF -> Hammond 60mH / 0.7 ohm -> 9400µF ->
In amp chassis:
A common mode choke -> DHT heater
If each DHT has it's dedicated CMC, would it be necessary to have the PSU section also dedicated to a single tube, or could I have the 26 supplied by a single PSU feeding the separate CMC's? The Hammond can put thru 2A, and I believe the 26 needs 1.05A.
So, all the way separate or not? Also, how good do you estimate this arrangement would sound? Any suggestions?
