dfidler:Links
= Getting Started =
* Why DIY?
* A/B switch for auditioning
* Class A, B, C, D
* Class A or Class B
* Analog Techniques and Audio (huge resource)
* Class A, B, C, D, E, F, G, H, Doherty
* Class G
= Celebrities =
[h=Linkwitz Labs]%2[/h]
[h= Zaph Audio]%2[/h]
[h=Art Ludwig]%2[/h]
[h= Rod Elliot]%2[/h]
= Construction Links =
== Bending Wood ==
* http://www.woodweb.com/knowledge_base/Vacuum_Veneered_Drawer_Faces.html - Bending Ply
* http://www.allwoodwork.com/article/woodwork/methods_of_bending_wood.htm
* http://www.woodweb.com/knowledge_base/Rx_For_Bending_Wood.html
* http://curbly.com/erika/posts/791-how-do-you-bend-plywood
* http://www.onlinetips.org/bend-plywood
== Applying Veneer ==
* http://www.io.com/~patman/finish.html#veneer
* http://www.joewoodworker.com/veneering/welcome.htm - Vaccuum Veneering
* http://www.rockler.com/articles/how-to-veneer.cfm - Techniques
* http://www.exotic-veneer.co.uk/exotic_wood_veneer_kitchen_office_reproduction_furniture_products.php - UK Supplier with big sheets
== CNC Milling ==
* http://www.cncrouting.co.uk/what/intelocking-mdf-frames.html - The Cutting Room - CNC Milling company in London; cool
* http://www.chromecow.com/downloads/lscript/shm-stl-tools/ - Lightwave STL plugin
== Aluminum ==
* Brushing Aluminum - must be done before anodizing
* Polishing Brushed Aluminum
* How to decide between Anodizing, Painting and Powder coating
* HowTo remove clear coat from Aluminum
* Best aluminum for anodizing is billet aluminum rather than pure ALU; pure alu has many impurities which can give it an uneven finish
* UK suppliers
* Best Aluminum for Bending
* How to Bend
* 18" Bending Brake
= Kit =
= Sonics =
* http://www.superlux.us/frequency_response.html - Why do Frequency Response Curves Matter
* http://www.physicsclassroom.com/class/sound/u11l3d.cfm - Behavior of Sound Waves
* http://www.slideshare.net/guest90e7e/reflection-of-sound-part-1-presentation
* http://en.wikipedia.org/wiki/Acoustics - Accoustics
* http://en.wikipedia.org/wiki/Reflection_(physics) - Reflection
* http://www.ndt.net/links/proper.htm - Plastic Material Accoustic Properties
* http://polymerphysics.net/pdf/JAcoustSocAmer_111_1782_02.pdf - Acoustic and dynamic mechanical properties of a polyurethane rubber
= Speakers =
== Projects ==
* http://www.diyaudio.com/forums/multi-way/93218-lgt-construction-diary.html-'LGT' Construction Diary
* http://www.linearteam.dk/ - Linear Team - Good free box design program (you need the T-S parameters from the speaker you want to use) Follow the help exactly to enter the parameters or it will not allow you to complete the entry.
* http://www.rjbaudio.com/ - RJB Audio - Projects
* http://www.planet10-hifi.com/boxes.html - Planet10 Box Layout Library - nice
* http://sites.google.com/site/undefinition/diy - Paul Carmody's Audio Projects - Projects (good site)
== Horns ==
* Horns - Math intensive! 🙂
* More words, less math
* http://www.frugal-horn.com/ - Horn Designs
* http://www.mh-audio.nl/Horn/Dinsdale_Horns_1.pdf - good article
* http://www.enjoythemusic.com/magazine/manufacture/zingali.htm - marketting stuff on how amazing horns are...
== Software ==
* http://www.speakerworkshop.com/SW/Download.htm - Speaker Workshop - Probably the best free speaker design package but it is evil to learn how to use.
* http://www.claudionegro.com - Speaker Workshop tutorial
* http://www.pvconsultants.com/audio/frdgroup.htm - Frrequency Response Data Consortium - Collection of very usefull simulation tools mostly in Excell. Th Baffle Step compenation program is really good for demonstrating how just moving a drive unit a few cm in a cabinet can significantly affect the frequency response.
* http://www.angelfire.com/electronic/loudspeaker/projects/speakerworkshop.html - Tutorial - one of several tutorial on how to use it (search the web for others)
* http://www.holmacoustics.com/holmimpulse.php - HOLM Accoustics - Probably the best free measurement software and fairly easy to use. You will need a microphone and a half decent sound card but that is all.
== Analysis ==
* Measuring Loudspeakers, Part One - very technical
== Books ==
* http://www.amazon.com/Sound-Reprodu...=sr_1_1?s=books&ie=UTF8&qid=1280935423&sr=1-1 - Floyd Toole's book on Sound Reproduction - recommended read; not cheap
= Uncategorized =
