DF1704 Input Word length
The datasheet for DF1704 shows that the input data format can be set to 16,20, or 24 bit. None are listen as a range like the output of CS8414 can be set (16 to 24 bit.)
If I have the DF1704 configured to a 24 bit input data format will it choke on a 16 bit signal ?
