designing crossover för Thiel and Eton...
Hi!
This is my first post/thread here and I´m from
sweden!
I need help designing a crossover for:
Thiel C12 + C89T or
Thiel C12 + Eton 5-880/25 HEX
the kombination
Eton ER-4 AMT + C89T
Eton ER-4 AMT + Eton 5-880/25 HEX
is also interesting!
Anyone that has any experience in those ? Should I go
for a bigger midrange like the 7-372/32 HEX? For
bottom I use 10" from TC Sound.
/Andreas
I'd also consider an 11" Eton woofers for the bass as well, Or have you already purchased the 10" from TC Sounds? The Eton woofers appear to have the advantage of high break-up frequencies, which lets you use small, high quality midrange speakers. You should also consider the C23 Accuton tweeter as an alternative to the C12, because it has a flatter impedance curve ie: less mechanical ringing, and therefore the crossover should be easier to design. However it is debatable because the C12 has other benefits thanks to its slightly smaller cone, such as wider dispersion.
The C12 would a better choice if it's crossed over at a relatively high frequency like 4kHz or 5kHz to avoid its resonance peak by a good margin, and if you use a midrange that performs beyond those frequencies. I would probably use the C79 midrange also from Accuton, and it has ferrofluid :bigeyes: . Because it is a true "midrange" speaker and not a "mid-woofer" it's only useful down to about 300Hz or so, and therefore the "11-581/50 HEX" Eton woofer would be a great match for it. In fact I think the top of the range Avalon loudspeakers use that very combination of speakers, or something very similar.
Have you considered the Excel series speakers from Seas? I think their 4.5" and 5" metal-cone speakers would be good options for the midrange, but probably with better bass performance. I think they would give a very rewarding sound if you can put notch filters in the crossover.
CM
I´ve been using those TC 10" for som years now and I would never change them for anything!! ;)
The thing is that I use the Thiel C23 and Eton 7-372/32 HEX in my system now. But I´ve never been fully pleased with the sound, dont think it come loose the way I want. Thinks that it might have to do with the "bigger" cone area and the dispersion you mentioned. I have had this system for 5 years now and thinks it´s time to do somethin new again. A friend of mine is interested in buying my old stuff.
I just came across a filtersolution for Thiel C12 and Eton 5-880/25 HEX. What pos and cons might the smaller midrange have compared to my bigger Eton 7-372/32 HEX? Or should I stay in size and get the Eton 7-360/37 HEX instead?
You can see a picture of the system here..
http://www.diyaudio.com/forums/showthread.php?s=&postid=314286#post314286
Your speakers look very good, but I think it's possible they could be suffering from the same problem that my speakers have. My speakers use the C2-94 7" midwoofer from Thiel & P, and the same C23 tweeter that your speakers use. For the bass I use a 12" mono subwoofer in a sealed box with equalization and a very steep crossover.
The problem may be that the midwoofer's box is too small. I'm not talking about "optimal" box sizes for bass frequencies, because who cares if the bass from the midwoofer is bad when there is a 10" or 12" woofer being used as well? According to Subwoofer Simulator the optimal size of a sealed box for the C2-94 midwoofer is about 4.2L, and about 6.7L for a ported box. 4.2L for a 7" woofer!?!? I made sealed boxes with about 15L each and a Qtc of about 0.42, and I still think they're too small. I'll explain why. Because the sound from the midwoofers and tweeters is so clean, reflections and resonances from inside the box are not masked and are easy to hear even though I used a lot of stuffing.
I found that both the C94 and the C23 have very good dispersion, good frequency response and the rest of it, but what bothers me is the sound that gets re-radiated from inside the box through the cone. I calculated that the surface area of the C94's cone = ~3.7% of the total hard surface area inside the box. This means that a large proportion of reflected sounds inside the box will reach the cone again before getting absorbed. For this I have 2 solutions:
1)Make an even bigger box with internal panels that reflect sound away from the midwoofer, or an infinitely big box.
2)Use a midwoofer with a smaller cone area.
By using a speaker with eg: half the cone area, the same-sized box could be almost twice as good because it's harder for the sound inside it to escape.
Perhaps there is a problem with existing crossover. What's the schematic for the crossover you currently use?
CM
Big thanks for your interesting thougts! Made me think!
Exactly like you mention I thought that the bass wasnt a big deal from a midrange woofer when I got the 2 10"! So I made a small enclosure with 3 layers of MDF , glued together with some sort of vibration damping glue. Dont hear to much through the cabinett, but never thought about the reflection through the woofer membrane!
I have the schematics somewhere, dont remenber much but it´s a 6dB/octave, dont remenber the cutoff freq.
Excuse my horrible english ;)
Ceramic Man ist right in saying that the midwoof box might be too small, although reflection from inside the box could be adressed with an internal baffle of , let's say 45° angle AND using some stuffing.
What I also notice is that your loudspeakers with those very capable TC's are basically crammed in the corners of the room, very close to the wall! Not good for an even frequency response.
Then it would be interesting to know the schematics of your Xover: I think there is no way you can get away with a 6dB filter on the Eton's. I once had a DIY speaker using the 7/360-37 HEX (very good!) and a Dynaudio tweet, and it needed at least 6dB PLUS an LCR network to suppress the cone breakup resonance at around 4 kHz (I was able to measure with Clio). I had 1,4 mH plus 5.6uf, 0.22mH and 2R2 parallel, when I recall this correctly.
Good luck,
Oliver
CM
Maybe this is also an option?
3) Deflex acoustic panels
http://www.deflex.co.uk/cgi-bin/deflexshop/deflexshop.cgi
Good luck,
Oliver
There´s a plenty of problems, not just my speakers, my listening room isnt optimal at all and I also got som earth hum there too. There´s actually no other way to place my speakers in my room then seen on the picture. In the near future I get a room twice as large, maybe that will solve some of my problem? If I rebuild my speakers with some not parallell surfaces with alot of stuffing.
I would be pleased if someone could help me explain how my filter works, didnt build it my self. Bought the system from http://www.goldenagemusic.se/, he knows what he´s doing... I think ;)
Hi Woofes,
I'm still having a look at the crossover you have now. Because you said you didn't make it, I'll take the liberty of, umm, analysing it as I go. :devilr:
Hmmm, woofer section: notch filter at about 4.2kHz to reduce the sensitivity of the woofer by about 5dB, as 5th Element said: to counteract the cone breakup...The cutoff frequency is hard to define. It's anywhere between around 530Hz at ~-44 degrees and -3dB, to ~1100Hz at -~65 degrees and -6dB. There is another, deeper notch at about 10kHz.
Tweeter section: Simpler 1st order filter, -3dB at about 2.9kHz (~-44 degrees), -6dB at about 1.8kHz (~-59 degrees).
Have you found that there is a distinct lack of midrange? Is the sound a bit thin, or slightly "un-rich". As far as I can tell, at 1.5kHz the tweeter is attenuated by about 7.2dB, and the woofer is attenuated by ~7.8dB. A 1st-order crossover with a big gap between the woofer and tweeter, all in all: pretty shocking. Back soon... :sly:
CM :devilr:
You should consider something like this (see picture) as a replacement. It's by no means perfect, but I think it's a bit better. Although it doesn't have the notch filter for the woofer, this shouldn't matter because the crossover slope is steeper. The woofer section probably could be improved, but the difficulty is with the 0.71mH equivalent voice coil inductance - it makes everything a little bit more difficult. I used a similar crossover for my speakers, and I used multiples of 2uF capacitors in order not to have to shop around for various different values.
If you try this, experiment with reversing the polarity of the tweeter because it has a fairly large phase delay.
CM :devilr:
CM :devilr:
Big thanks! Thats pretty shocking! Cant believe it! The sound is just like you describes. If this is true I go for your crossover CM!! Or I sell it and go for the C12 and 5-880 instead. I just got crossoverschematics for that combination.
CM, how about this, 1.8mH in series with Eton 5-880 and a 10uF in parallell. 5uF in series with the C12 and then 5ohm and 10ohm.
Where have you learned yourself everything CM?
woofes said:
...Where have you learned yourself everything CM?
Engineering course at Tech. We learned about electronics and other things... But mostly I've taken an interest in audio as a hobby, so I've learned a lot by experimenting and thinking about things.
For the 5-880 and the C12, probably the simplest crossover that would be ok would be:
Woofer: 0.6mH in series, 10uF (+ 1.5ohm in series with capacitor) in parallel.
Tweeter: 6.8uF in series if it has to be 1st order, otherwise 4.7uF in series and 0.6mH in parallel. I'm not sure if the tweeter needs to be attenuated, maybe 1ohm in series next to the tweeter.
I would still prefer to make the crossovers a little more complicated. Woofes, you need to find a new supplier for inductors and capacitors - they are obviously costing too much! :).
There are online calculators for working out crossover values, but I think that many of them are not very good. They don't take into account the equivalent inductance of speakers for example. It is the resistance element of a speaker's impedance that creates sound, the inductive part just stores energy. Therefore designing a passive crossover isn't easy. The electrical performance of the crossover should also take into account the frequency response of the speaker when there is no crossover.
Whenever I've wanted to work out a passive crossover, I've used "Multisym" demo from Electronics Workbench (somebody help me, there must be something better than Multisym!). With it I can draw a schematic, place signal generators and connect Bode plotters, to tell me how a crossover will perform. I usually don't even bother making theoretical calculations, but tweak the different values to get the best performance.
I think that active crossovers are better, but they are harder to design, but then again they're not that hard. Has anyone got a link to Butterworth tables and calculations?
CM
Hi: I am a new member to this site. I found this thread when searching the Web for information regarding the Thiel C23 tweeter. My current speaker (Hales System 2 Signature) uses a MB Quart MCD25 tweeter which has a rated 91dB efficiency, 8 ohm norminal impedance and 6.9 DC resistance, resonance frequency is 990 Hz. It's crossovered at 2KHz with a 2nd order filter to a pair of DynaAudio 17W75 midbass drivers. I've been considering replacing this MB tweeter with the C23. I do not know much about speaker technology but am wondering how this change will affect the tonal balance and over all performance of my speaker without making change to the crossover. Any suggestion or comments will be greatly appreciated. Thanks!
