Thanks for advice.
Where can I buy that woofertester ?
Can I get in singapore ?
Here is my subwoofer.
U can see in photo.
Rumbling sound of that woofer is good.
But need a lot of power.
I think dipole is more efficient than my woofer.
Can dipole woofer get rumbling sound ?
If I used paper
U can see in photo.
If I used paper
Order It
You can order it here.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=390-802
It takes just a few minuites it will give you about all your subs parameters.
Hello jwatts,
I am very interested that woofertester.
Can that woofertester test accurate ?
I want to order.
But That will be very difficult to order from our country.
Which country can buy easily & cheapest ?
USA or Singapore
And then ship to myanmar.
Pls, advice me.
Thanks.
I want to order.
USA or Singapore
Pls, advice me.
Thanks.
Hello jwatts
Thanks for yuor help.
I will buy that tester.
I think I will wait one or two months to get that tester.
Hello jwatts,
I already order that tester.
I think, I must wait a few weeks.
Continue help me when I use that.
Bye.
Bye.
Hello Friend,
How can I calculat Power Handling & other parameters with that woofer tester?
I think woofer tester cannot test all parameter of speaker.
Is it true ?
Where can I learn speaker's parameter ?
Pls, help me.
Thanks.
Is it true ?
Pls, help me.
Thanks.
Hello Friends,
Pls, help me.
how can i use my woofertester?
I already asked woofertester.com.
They advice me buy speaker design cookbook.
Is there any other way?
I don't want to buy book.
Pls, give me web links or documents which explain about SPK parameters.
Pls, help me.
hello friends,
Now, I tested new woofer which is upgrade from my old woofer.
http://www.diyaudio.com/forums/attachment.php?postid=845270&stamp=1139919766&
I delete AMP section, replaced passive radiator in the AMP section & closed the port.
I like that woofer sound very much.
But there is something wrong.
sometime I heard coil knock sound. ( very seldom not always ).
Is that Resonance ?
How can I tuning that woofer?
I already tunning with weight which is on passive radiator.
I think somebody will help me.
I will post that woofer photo.
Pls, help me.
Sorry for my poor english.
Myanmar.
Is that Resonance ?
Pls, help me.
Myanmar.
I found the problem.
That will happen when I use UPS power. ( always no electricity in our country ).
So, How can I repair that problem.
Pls, continue help me.
Myanmar.
Myanmar.
You are maybe not far off with the bent pipe... I bleieve the Logitech subwoofers (PC speakers) have a spiral or curved port...
Here is my spk specification.
Open air & With Box.
How can I know my woofer is good or bad when I see that graph.
Pls explain me.
Regards.
Pls explain me.
Regards.
- Subwoofers
- Design GIGAAMP SubWoofer.
