Hello,
The parameters of the OCXO are extracted , and phase noise is about -104dBc@1Hz on average.
It could work (and a notch may help clean up) but -70dB seem pretty average close in phase noise? Not that it really made too much difference getting to -100dB, the power supply had more impact so what will you feed these with?
I want to verify if the method in [1] can help to obtain a better result. -70dBC is the original one. Battery is used the same as that in [1].
Standard audio oscillator frequencies are included in table at: https://en.wikipedia.org/wiki/Crystal_oscillator_frequencies
Can you hit any of the audio clock frequencies used for 44.1kHz or 48kHz audio frame clock families?
