DER EE DE-5000
Try measuring some resistors under 1,000 ohms to determine if your measurement technique is faulty or if your meter has a problem. One of my DE-5000's developed a problem where resistance measurements below 1,000 ohms were over 10% off. Found a thread on the EEVblog where an owner had a similar problem & fixed it by replacing one resistor. Replaced the one bad resistor in mine & now it's well within specs on resistors and small capacitors.
See:
https://www.eevblog.com/forum/testgear/der-ee-de-5000-lcr-meter-calibration-and-adjustment/
Reactions: olen
