Depletion power MOSFET
knutn, did you find some IXTH16N10D2 ?
i've tried two times now, getting IXTH16N10D2 fakes from hong kong and china on ebay ( two different sellers ). those i've got didn't operate as depletion mode ( they acts like enhancement mode ). the weird thing is, the mosfet's don't look like fakes, they look like genuine ixys. maybe they're wrong marked from ixys.
i know this thread is old, but i want to know if some genuine ones can be found out there.
it seems hkutsource has changed subject name ...depletion is not mentioned anymore ( still they're fakes, because they don't act as depletion mode )
http://www.ebay.com/itm/IXTH16N10D2...871458?hash=item5651a3b822:g:v88AAOSwzrxUxeyn
here's the IXTH16N10D2 documentation
http://ixapps.ixys.com/DataSheet/DS100258C(IXTH-TT16N10D2).pdf
agdr said:
Here you go, 6 in stock at Mouser:
IXTH16N10D2 IXYS | Mouser (IXTH16N10D2 IXYS | Mouser)
Mouser part #747-IXTH16N10D2, $8.93 USD each.
Hi agdr
I forgot to tell, one of my friends also ordered some from RS some months ago and they should not be fakes, but they also seems "not" to act like depletion modes. My thoughts, maybe there have been failures in production-series at ixys, which is not really depletion mode mosfet's (?). Anyway i have to try other dealers and find some that works.
I already had seen Mouser got them ( thanks anyway ) ...so it was not that i didn't knew about their stock. My request was more about, if anyone could point out a dealer, where there was a guarantee of genuine ones or should i say a production series that is what it is on paper.
regards from Kramme
The data sheet shows Vgs off is between -2 and -4.5V and that ID>16A measured at Vgs=0, Vds=25V. No debate about depletion mode at all
no debate, so you say IXTH16N10D2 is a depletion mode ?
if i understand your info and the data sheet, the depletion mode works only as ( negative ) - vgs and the vgs is between -2 ~ -4,5 which tells it's a depletion mode ...right ?
if so, it's fake components ..no doubt about that. mine works only as ( positive ) + vgs. 😕
