Greetings to all. I have just inherited a Denon DRA 345 receiver. It is in mint condition but there seems to be a problem with the output power. When playing with any of the source inputs as well as the tuner the right channel is inaudible unless the balance dial is set at the position just before it slides into "full right". In this position both right and left are pretty much equal, only if the right speaker is hooked up to the "B" speaker side. Not so lucky on the "A" side. I would like to get this working properly if I can. Is it worth trying to repair?
Thank you for time and replies.
Sardeter
Sardeter
take a look at the balance pot.
i would think it could use a replacment.
you can get rid of it to see if both channels are equality loud.
if so then the pot was the source of the problem.
Thank you Arty. After a bit of looking and dis-assembly I managed to get to the balance pot. I gave it a good clean as well as the rest of the receiver and it seems to be working fine. I have no idea how long it had been since it was last used but it really needed one.
Sardeter
Sardeter
