Denon AVR1708 won't drive Polk speakers
Received an email from a friend in regard to his new Denon AVR1708 receiver stating that he cannot use his Polk Audio 5JR's without the receiver going into protection and shutting down.
I am told the specifications for the Denon are for a load of 6-16 ohms and the Polks are 4 ohm nominal. The question is should the Denon be able to power the Polks without the protection circuit turning on? Is the Denon at fault? Is the load too great?
Any suggestions for using the Polks with the Denon? Impedance matching box?
THEthe "impedance matching box" would probably just be a 4 ohm resistor, which if you're buying it commercially as a "black box", you're probably paying way too much. you could probably equip a complete surround system with 4 ohm 50 watt resistors for the price of one "impedance matching box"
