Denon AVR-1403 Pre-out's
Case closed for now
The case is closed for the time being...
I found out that all ine I/O's and the speaker terminal "negatives" share common ground reference. Therefore, the case is solved to my satisfaction by creating a simple resistive voltage divider to mount on the speaker output, and connect it as a normal line source to my existing equipment.
Jennice
