For Sale Deluxe large aluminium chassis plus heatsinks (Maybe UK only)
Things you have for sale.
Beautiful case with rounded corners, this one here ENCLOSURE
W x 380mm H x 89mm D x 320mm
This has blank rear panel with no cut out as I wanted to use Power-con connectors.
Included are two 300mm x 70mm x 50mm heatsinks which fit inside the case perfectly, also 4 x 40mm feet, 2 x sets of Neutrik RCAs and Gold plated speaker binding posts.
This all weighs a few KG so would better for a UK member as postage is not cheap. Probably cost around £10 to send in UK.
SOLD
