Delta HD9 CRT Lens Question
I am looking at making a projector, and as I have a 7" Lilliput already, I would like to base it around that.
I'm looking into getting a Delta HD9 CRT lens on Ebay (http://cgi.ebay.ca/Barco-Electrohom...ryZ75404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem), and I would like to verify that it will work. After a bit of digging around, I found out that this is from a Barco projector with a 8" CRT (http://72.14.209.104/search?q=cache...o_data.xls+delta+hd9&hl=en&gl=ca&ct=clnk&cd=1[/url]).
Is this lens big enough to work with the Lilliput? Also, that spreadsheat says that the CRT angle in the Barco projector that uses this lens is 10.5 degrees. What does that mean exactly?
