Hello all,
I'm trying to extend the dell e153 FFC and wanted a little help finding the right cable (maybe from mouser? whatever is cheapest/best/easiest)
Here are the pictures of the ffc, is 20 pin but less are actually used. I would love some help on where and what I need to buy.
-spy
-spy
https://secure.lumenlab.com/shop/product.php?id=12
That is what you need 20 pin .5 pitch ^^
good luck
good luck
can anyone tell me if that white connector in the first picture is a zif vertical or right angle or maybe something else?
The reason I ask is that there was a black clamp on top that would swivel down and clamp the ffc cable down... but that thing was so delicate that it broke. I basically want to order another connector and use the swivelling clamping part from it to replace the broken one.
If I cannot do this....what do y'all suggest? pour hot glue on top?
Thanks for any advice
-spybld
-spybld
A zif is a zero insertion force socket. In a Zif there is usualy a little peice of plastic you have to lift up, then the ffc will come out easily. Since the socket is at a right angle to the PCB that means its a right angle socket, however, I am not sure that you need this info to extend the cable.
sound_prodigy said:A zif is a zero insertion force socket. In a Zif there is usualy a little peice of plastic you have to lift up, then the ffc will come out easily. Since the socket is at a right angle to the PCB that means its a right angle socket, however, I am not sure that you need this info to extend the cable.
Thanks for the explanation, the reason I ask is that it is that very same little piece of plastic that is broken for me... so now when I insert a cable into the connector, it won't stay there for long. I was hoping that if I bought another connector, I could use that part from it ... but I dunno. Any ideas on how to get it to stay in the socket without the plastic piece?
-spy
- General Interest
- Everything Else
- The Moving Image
- LCD
- dell e153 ffc issue...
