Definitive amp and sub blown
Pf15tl plus the amp is fried and I was hopin to rebuild it myself. Is this possible and does anyone have a picture of the amp so I can figure out what resistors I need. I am not a pro just trying something new any advise would help greatly
PF15TL humming and popping?
I have a pf15tl that was repaired last year. Recently it would make random popping sounds when not in use. Now it makes a loud humming sound without even being connected to low level inputs. Unplug the power and a loud pop sounds occurs.
I have not really used the sub since the last repair and
it wasn't being abused when it died. In fact it was plugged in but disconnected from reciever due to random popping sounds.
the red power led is on.
The 2 terminals the feed the sub have 55 volts at idle. (Nothing connected just 115vac on power cord)
I'm assuming this is the hum that I hear.
I checked the components that have been mentioned in other posts and they check good.
Any ideas would be greatly appreciated.
cheers
Tom
