default mods to preamp?
The thing is I cannot find sw601 anyware, I traced down where the switch should be connected on thepcb layout in the service manual, but from there a jumper wire is running. So i need to open the preamp tonight to have a look again.
Meanwhile while i'm in there tonight, should i bypass (wire) R223 and C261, R224 and C262?
Anyway Thanks for your help.
there is little difference between the 25K and 20K pot values. go ahead if you think this is a good value experiment.
But, before you fit it compare the passive Dact with the active NAD. That comparison might give you some sound references to work with.
I replaced C279/C280 by a wire. When I measure dc at those wires I measure 0.9 and 0.4 mV.
At the positive side of cap C266/C265 I measure 0.8mV and 1.2mV.
So not a lot of dc offset I think.
One other thing. When I inserted 4 AD843's (on browndogs) tonight I get atrsnage crackling noise (quite loud) when I turn the volume all the way down, this happens at the lowest part of the volume control.
I out the opa2132's back in and the issue is gone. I found out that only a AD843 couple in IC208 position is causing it.
Any idea what this can be?
