**** LOCAL SALE ONLY *****
Selling a pair DECWARE Nibbelin UltraFlex - Model NFX speaker cabinet with Fostex FE206e drivers.
This kit needs final assembly to be complete. Everything is included necessary to finish the speakers.
Now for the bad news...nothing serious but is important.
* The center cap in one of the Fostex FE206e's has come unglued and needs to be re-glued in.
* The cabinets need to be veneered or painted
* You've gotta wire up the speakers to the speaker binding posts
I don't have the time to finish the project.
Here are the specs:
SPECIFICATIONS
99 dB with 1 watt at 1 meter
58Hz ~ 20kHz flat
48Hz ~ 25kHz -3dB
8 ohm nominal impedance
Crossoverless
2 ~ 60 watts
Max SPL 115 dB
Size 12.5" wide, 17" deep, 42.5" high
Ultraflex cabinet
Thanks for looking.
NOTE:
That last picture is just an EXAMPLE of the speaker can look like. It is NOT the actual speaker up for sale here.
Includes:
2 - Professionally Designs MDF Cabinets
2 - Fostex FE-206e Speakers
8 - 7" Foam Balls for the inside of the cabinet
(2 pr) Speaker binding posts
4 - Rubber feet for the bottom of each cabinet
DECWARE Plans for your records
After doing more research I found out these are the DECWARE modified Fostex FE206e's called by DECWARE the DFR-8.
ASKING $475 or best offer.
Here are the specs:
SPECIFICATIONS
58Hz ~ 20kHz flat
48Hz ~ 25kHz -3dB
Crossoverless
2 ~ 60 watts
Max SPL 115 dB
Ultraflex cabinet
Thanks for looking.
NOTE:
Includes:
The Decware FE206 adds a foam surround over the fanory surround. And his, i wa sin the shop and spotted a socket that would fit into the hole left aftwer a dustcapectomy.
I note the 99 dB spec… this is boasting by Steve, the loudspeaker will be no more efficient than the FE206 as a front radiator, ie 96dB, and the extra surround willreduce that somewhat.
dave
dave
They haven’t been altered from my knowledge.The FE206E did not come with foam surrounds....
Have these been reconed or altered?
Thanks for adding that info Dave. I appreciate it.The Decware FE206 adds a foam surround over the fanory surround. And his, i wa sin the shop and spotted a socket that would fit into the hole left aftwer a dustcapectomy.
dave
