Hi just complete my Decware DIY SE84 amp and one side there is a issue.It plays ok for a second then slowly the volume falls to almost zero.I check the tubes,swapped tubes,cable,check the caps.Everything seems ok.The single driver tube by my tube tester indicates its weak.Could a single driver tube cause the inbalance of the channels volume?.
