Decimals in LTspice
Hi
Is there is a simple way to increase the number of decimals in the percentage result of a .four command?
The individuals components are displayed in a floating format, but the global THD result has a fixed format, with only 6 decimals.
THX
Hi
THX
There probably is, but even at 6 decimals you're way over any reasonable correspondence to reality. Additional decimals are only cosmetic and at worst put you in the wrong direction.
jd
