Dead Studer A730
check for fuses
at the risk of suggesting the obvious, is there an internal fuse ? I have an old Philips 104 and the Power supply has a fuse on the circuit board , accessible only from underneath, having removed the lower plate.
Hi, Everybody,
I've looked more closely through the dead StuderA730.
-From outside panel (keyboard) not 1 single LED is on. All LEDs and 7segments are off, no matter what button I push, nothing happens.
-If I put a CD inside the tray, the CD spins, but no LED or 7segments is on. All indicators are dead.
-All the fuses are OK, the DC voltages from power supply are all present and normal. 2 LEDs are illuminating inside the unit, one red LED and 1 green LED on the right-down corner.
-The power supply heatsink (a piece of aluminum sheet) is a bit hot.
-There's an IC with code SAA7220 (position near TP5-TP6) is very hot. Is this normal? From the datasheet it is a digital filter IC.
Here's voltage measurement on Test Points (TP) as I measured them VS as written in the service manual.
I measure the voltage in dead condition, the service manual said the voltages are in "play mode", so could be different.
Anyone can help to interprete what is going on?
