Hi, I have a dcx2496 processor. I would like to know how to correctly output it with the bass signal. As far as I can see, there are two options: the first is the output from one of the Low channels, the second is the output of the SUM of both channels. This is where my problem comes in.
I would like to use a limiter for subs. When testing "dry" on the SUM output, I set the limiter to -20db and it works. At about 70% of the signal power fed to the processor, the limiter starts working. However, the same setting on the "Low" output completely does not activate the limiter, even turning it to 100% does not activate the limiter. On the scale it does not even reach the -20db. I know the difference is that SUM sums both channels into one and we have + 6db there? (if I am wrong please correct me). Can someone explain to me how it should be properly configured (and why so), so as not to blow the bass? 🙂
If there is anywhere to read about it, please link
