DC protection
Gooday all,
I need some advice please. When I switch off an amp,then there is a crack on the speakers because the protection circuit relay takes too long to switch off. If I decrease the 470uf capacitor to something smaller like 100uf or even smaller, would that be the best option to make the relay release faster ?
Thanks all.
  • dcdetectschematic.pdf
Thanks guy's,
Would adding a snubber like this be helpful ?
Administrator
Joined 2007
Can't disagree with anything that has been said above.
One thought would be to try adding a reverse biased diode across the 330k to discharge the timing cap on power off... but it still wouldn't be instant off.
Fwiw, I use schemes that Doug Self put forward back in the 1990's and that include AC drop out detection. I've never had the slightest noise whatsoever on power off when switching even 600VA toroids.
Maybe the mains switch is a bit suspect and prone to arcing more than it should.
