DC on output
udip said:
sajti, I think you are right..
I checked on scope and I can see a triangular wave on the output
of servo with input, but only with low frequency.
That's servo oscillation?
If i put a non-inverting servo to the - input of opamp, should I
use some sort of bias to the + input in order the eleminate the
feedback to ground capacitor?
Thanks...
If You use non inverting DC servo, just connect the input transformers secondary to the ground. It's not necessary to use any bias. Use DC servo, is to avoid the feedback capacitor.
sajti
Hi peranders,
Thanks,
I'v been playing with the simulations....and it's ok...
but if you noticed in my preamp the servo is in a completely different configuration, as it's output goes to ground via resistor
and changing the bias on the + input of the main opamp (I think)
In the simulation there is no indication of AC output the comes
back to the main opamp.....
So I guess this it's not the common use of servo in the
IN and NI configurations..
I'm sorry about all those questions I'm asking.....
I have 2 more:
1)Should I check for offset with inputs shorted?
2)The servo output is a triangular only when input is distorted.
Is this ok?
Thanks again for your help....
